AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Opening ASD 2010 Steel drawing with ASD 2013 - Fatal error
7 REPLIES 7
Message 1 of 8
Priitl220
1027 Views, 7 Replies
Should I be able to open ASD 2010 steel drawing with ASD 2013 version?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
7 REPLIES 7
Message 2 of 8
lucis29
in reply to: Priitl220
Of course. The other way arround is not possible.
Message 3 of 8
Priitl220
in reply to: lucis29
Have you tried it yourself?
For me it causes fatal error.  I have tired with two different drawings.
I can not post the drawings, as they contain sensitive information.
And I cannot produce any other sample file, as I do not have ASD 2010 installed.
P.S. The other way around .... was not the question.
Message 4 of 8
I think sometimes it happens but please try to share the file.
We have abilities to check it closer and possibly fix.
BTW is 2010 version file saved on priintout or model tab?
Jakub Brożonowicz
Global Product Support
Message 5 of 8
lucis29
Yes. Off course I've tried. Otherwise I wouldn't have answered.
Try to open the back-up file.
Message 6 of 8
Jakub.Brozonowicz
Finally it was solution by opening with recover in 2011 and saving there.
Next attempt of opening it in 2013 finishes successfully.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Message 7 of 8
lucis29
in reply to: Jakub.Brozonowicz
So, that means ASD2011 is the most stable and the best version? I still vote vor ASD2012 as beeing the best until now.
Message 8 of 8
Jakub.Brozonowicz
This solution accepted is just incidental - in such case only.
General conclusion about stability is rather unjustified.
But I can confirm that most of all examples are not easy to open in 2013.
Jakub Brożonowicz
”Boost
”Tips
