AutoCAD Structural Detailing General
Valued Mentor
ybogdanov
Message 1 of 7 (438 Views)
Navisworks integration
438 Views, 6 Replies
09-22-2011 02:45 AM
 now I probe to open one Structural Detailing file with Navisworks, and the properties of elements don't view. (I was installed the object enabler of Structural),
Is normal?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Product Support
lee.mullin
Message 2 of 7 (412 Views)
Re: Navisworks integration
09-26-2011 06:44 AM in reply to: ybogdanov
Can you attach a sample file?
Which version of Structural Detailing and Navisworks are installed?
In Navisworks can you take a screenshot of the Options > File Readers > DWG/DXF/SAT and upload this please?
Does this work when you export an NWC from Structural detailing ( if the exporter is installed then 'NWCOUT')
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
Valued Mentor
ybogdanov
Message 3 of 7 (408 Views)
09-26-2011 01:41 PM in reply to: lee.mullin
The version of both products is 2012.
This is the screen capture of configuration of the dwg reader:
And attach the nwc file exported with the NWCOUT command, and the dwg file of the structure.
Yury Bogdanov
Barcelona (Spain)
Valued Mentor
ybogdanov
Message 4 of 7 (406 Views)
09-26-2011 01:46 PM in reply to: ybogdanov
Yury Bogdanov
Barcelona (Spain)
Valued Mentor
ybogdanov
Message 5 of 7 (405 Views)
09-26-2011 01:48 PM in reply to: ybogdanov
Sorry for the various post, is because the foro don't accept files biger 1,5Mb
Yury Bogdanov
Barcelona (Spain)
Product Support
lee.mullin
Message 6 of 7 (394 Views)
09-27-2011 03:45 AM in reply to: ybogdanov
Everything seems fine with the options, can you upload a screenshot of the properties of an object in AutoCAD and the equivalent item in Navisworks with the properties window open?
I assume you have the 2012 AutoCAD Structural Detailing Object enabler relevant for the machine, i.e. you need 32 bit on 32 bit and 64 bit on 64 bit.
Lee Mullin
Global Services
Autodesk Ltd.
Valued Mentor
ybogdanov
Message 7 of 7 (267 Views)
10-12-2012 05:25 AM in reply to: ybogdanov
Hello, after one year I see that the 2013 release of Structural Detailing and Navisworks, continue without properties integration.
 I want to see type of each steel member, and position in Navisworks, it's posible?
Yury Bogdanov
Barcelona (Spain)
You are not logged in.
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
