AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Memory and performance
4 REPLIES 4
Tony_Gibbs
551 Views, 4 Replies
HAs anyone got any comments on how autocad handles performance of a structure model as it increases in size.
For me the larger my model gets the slower Autocad is until a point where it is almost unusable.
I'm even having to split the model into smaller ones to keep up performance.
Any sugestions would be greatly appreciated
Tony
4 REPLIES 4
markhubrich
in reply to: Tony_Gibbs
I seen the same issue. I now have installed 24gb DDR3 ram and it is much better. How much ram you have? You using 64bit Windows?
Mark
...and fix the kiss export issues.
jad.dellel
in reply to: markhubrich
If you use  ASD2012, you should install the AutoCAD 2012 performance slowdown hotfix (32/64 bits)
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Tony_Gibbs
Thanks Mark I'm using 64 Bit Windows 7 with 6GB memory
Regards
Tony
markhubrich
in reply to: jad.dellel
Is there one of these for ASD 2014? I have the best workstation available and performance is far less then would be expected.
”Boost
”Tips
