AutoCAD Structural Detailing General
Active Member
jpassociates
Message 1 of 10 (1,043 Views)
Macros
1043 Views, 9 Replies
08-25-2012 06:21 AM
I used the base plate macro and made a elongated cap plate with holes. It seems to work ok on one column line, but It needs it to mirrored on the opposite column line. It's not working, what am I doing wrong. HELP.
Valued Contributor
lucis29
Message 2 of 10 (1,014 Views)
Re: Macros
08-29-2012 03:12 AM in reply to: jpassociates
Please add some pictures.
Mirror command only works in XY plane!!!
Active Member
jpassociates
Message 3 of 10 (946 Views)
Macros
08-29-2012 06:13 PM in reply to: jpassociates
I am using the the base plate macro. I am trying to have a 2-hole on 1-side 6" apart and at 90 deg. 2-more holes 6" apart 18"x18"x1 1/4" PL. I got it to work one side but i couldn't on the 90 deg. side. Thanks
Valued Mentor
Rich.O.3d
Message 4 of 10 (998 Views)
Re: Macros
08-30-2012 04:27 PM in reply to: jpassociates
from what I have seen, ASD does not play well with the mirror command
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Active Member
jpassociates
Message 5 of 10 (984 Views)
Re: Macros
08-31-2012 05:24 AM in reply to: jpassociates
If I can't use this base plate macro for this particular plate. Could I use the plate macro and add holes where I need them? If so, How would this work.
Product Support
Jakub.Brozonowicz
Message 6 of 10 (976 Views)
Re: Macros
08-31-2012 07:20 AM in reply to: jpassociates
Do you have any chance to show it please?
Jakub Brożonowicz
Active Member
jpassociates
Message 7 of 10 (972 Views)
Re: Macros
08-31-2012 09:41 AM in reply to: jpassociates
Product Support
Jakub.Brozonowicz
Message 8 of 10 (933 Views)
Re: Macros
09-03-2012 03:14 AM in reply to: jpassociates
Look at movie here.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Active Member
jpassociates
Message 9 of 10 (917 Views)
Re: Macros
09-04-2012 05:19 AM in reply to: jpassociates
Thanks for the solution.
Active Member
jpassociates
Message 10 of 10 (829 Views)
Re: Macros
09-12-2012 04:05 AM in reply to: Jakub.Brozonowicz
Holes needed at clouded area. With all the hole variations for that base plate macro, I can't get it to show those clouded holes. Help please.
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
