• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    New Member
    Ladder and cage alignment with extend & direct Vertical bars (stringers)
    370 Views, 3 Replies
    10-15-2012 05:34 AM
    Hi there,
    I'm quite new to ASD but have adapted nicely so far without formal training, however I have one issue that I can't seem to figure out...
    I have a catladder arrangement with vertical bars that are direct and extended (widened) at the top, when I create the cage it does not create a smooth transition along the vertical bars? Am I doing something wrong?
    I have an attached picture to show what I mean.
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: Ladder and cage alignment with extend & direct Vertical bars (stringers)
    10-16-2012 05:48 AM in reply to: marci.dup
    Truly said screen is not enough.
    Maybe the sample dwg file you have?
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Active Member
    10-17-2012 04:33 AM in reply to: Jakub.Brozonowicz
    Hi Jakub,
    Here is the ladder and cage.dwg (2013).
    Thank you!
    -=StevieWonder=-
    "Trust me, I'm a draftsman"
    Product Support
    Jakub.Brozonowicz
    10-18-2012 03:54 AM in reply to: StevieWonder
    I am affraid that the cage is not possible to align to the extended widened vertical bars.
    For me it is rather a field to improve the functionality but you can model something similar instead of it.
    Look at attched model.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Jakub Brożonowicz
    Support Specialist
    Product Support
