AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
LyleHardin
1491 Views, 3 Replies
Knee Brace
Is there a way to create a Knee Brace in ASD? I'm using 2013. I found a workaround in this thread:
http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/Creating-a-knee-barce-in-ASD-2012/m-p/316...
  Clever and it works, but I'm hoping for a better, more default/straight method.
We want to place knee bracing from a column to a beam using gussett plates.
3 REPLIES 3
in reply to: LyleHardin
Can you sketch what you need? I'm not vey sure what a "Knee Brace" is.
LyleHardin
I've attached a Knee Brace image using a screen shot from Revit Structure.
Basically it's just an angle attached to a column and beam with gussett plates.
ASD's Bracing comes close, but it needs two columns and it creates an X bracing.
This is a pretty common brace, I'm not sure why it's so difficult to do in ASD.
It should maybe be an option in Haunches.
Now I understand. Yes, I believe that the bracing solution is the only one. Or you could model every element.
”Boost
”Tips
