• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Just what will this program DETAIL?
    530 Views, 4 Replies
    01-13-2010 08:06 AM
    We were looking at 3D steel detailing software for awhile and finally went with another company. However, we do as much if not more process ducting (air scrubbers, exhaust stacks, etc) than we do structural detailing.
    Will this program model and detail platework without having to manipulate for hours? Which is exactly what the "other" company's software requires. It's possible, but extremely difficut.
    Please use plain text.
    Re: Just what will this program DETAIL?
    02-24-2010 11:42 AM in reply to: JasonAB
    ASD is able to do plates as well as structural steel. The plates are easily modified. (Cutting, bending, etc.) You can also make a plate to fit any contour you can make using polylines. Hope this helps.
    Member
    02-28-2010 05:22 AM in reply to: JasonAB
    Is this software able to do 3D concrete detailing ? like Tekla.
    Thanks in advance!
    New Member
    04-22-2010 01:51 PM in reply to: JasonAB
    Hi, I just poped in to your discussion and got interested in the topic, we have just purchased the copy of ASD 2010 and we do more strucuture detailing, sometime I have to to a Tank, How do u bend a plate? I still find it deficult to make bent plate. is there a quicker way of doing it?
    05-06-2010 05:00 AM in reply to: JasonAB
    First off, as soon as possible, update to ASD 2011. There are many issues in 2010 that are corrected in 2011. To bend a plate, first draw the plate in the flat layout. Then go to ASD - Model > Machining > Bent Plate and follow the prompts to bend the plate. To do a rolled plate, create a profile of the cross section of the plate and then go to bent profiles. Draw a polyline of the radial path to create the rolled plate. Hope this helps.
