AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
How to show neighboring parts in an assembly 2D layout and reference dimensions
1 REPLY 1
412 Views, 1 Reply
This query is in ASD.
While creating a 2D assembly drawing out of my 3D ASD model, how do I add the neighboring parts and add reference dimensions to these items. See the below example case.
1. Consider a Secondary Floor Beam with Assembly Position SB101, which is supported by a Main Floor beam with Assembly Position MB202 at the start (of SB101) and supported by a Main beam with Assembly Position MB203. Assume all Sections are of Profile type I.
Question : How to generate a 2D layout of Assembly SB101 along with cross sections of the two Beams supporting it (viz MB202 & MB203) ? How to add dimension from Centerline of MB202 & MB203 to the nearest edge of the Assembly SB101?
2. Similarly, how to generate such assembly 2D drawing where a beam is connected between 2 columns. In this case, I want to have the elevation of the column section on either side (cut to a specified height).
May anyone please provide a solution please?
Tamilarasan
1 REPLY 1
Hello............
Is there any one.... here.....
Please wakeup Autodesk....
Please answer my question.
”Boost
”Tips
