AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
How to create section views
7 REPLIES 7
Message 1 of 8
1163 Views, 7 Replies
what are the steps for creating a view port i follow the comands but i can never get the section to come out in the view port
7 REPLIES 7
Message 2 of 8
zcsillag
Use Revit ... or other software
Regards
Csillag Zoltán
Message 3 of 8
Can you explain what you're trying to do, and the steps you're using?
If I know what final result you're trying to achieve I could probably help.
Message 4 of 8
in reply to: zcsillag
What is the point of ASD if you can't cut sections?
Message 5 of 8
You can cut a section, I've done it before.
I'm busy at the moment, but if someone else doesn't answer your question I'll post some screenshots of the process later today.
Message 6 of 8
I mistake i was using the wrong type of view port i got them working now thanks tho Smiley Tongue
Message 7 of 8
Great! Let me know if you have any more questions 🙂
Message 8 of 8
iainsavage
Now that you have worked out the solution, could you now please share the answer for the benefit of others?
”Boost
”Tips
