AutoCAD Structural Detailing General DIscussion
Active Member
cashansa
Message 1 of 5 (551 Views)
Accepted Solution
How to copy connections easily?
551 Views, 4 Replies
08-30-2013 11:50 AM
Good day All
I am having problems trying to copy certain connections. Please see the attached file.
I have taken a typical rafter and purlin example.
At x = ~ 6m (UCS), there is a "macro connection". I cannot copy this connection along this rafter to the other purlins. Any suggestions?
At x = ~ -2m (UCS), there is my custom knee brace connection. To copy this detail to the other purlins is tedious and annoying. Any suggestions to make this task easier? It is much worse on large projects.
May I also request Autodesk to create a "custom connection" macro. In this macro one may draw a connection, save it as a template, and then copy it to other parts of the structure where required. Of course, I do not expect the custom connection to be editable.
Kind Regards
Product Support
Artur.Kosakowski
Message 2 of 5 (525 Views)
Re: How to copy connections easily?
09-02-2013 06:16 AM in reply to: cashansa
If you select all purlins after selecting the rafter the connections will be generated in one run (see the attached picture).
The request for the custom connection option is on the wish list for ASD Steel.
Artur Kosakowski
Active Member
cashansa
Message 3 of 5 (519 Views)
09-02-2013 06:42 AM in reply to: Artur.Kosakowski
Thank you for the reply and the custom connection request. What possibility is there that by the next release the "custom connection option" is available to the users?
Regards
Product Support
Artur.Kosakowski
Message 4 of 5 (516 Views)
09-02-2013 06:51 AM in reply to: cashansa
I'm sorry but we are not able to provide any information about the next releases till the moment they are officially announced by Autodesk.
Artur Kosakowski
Active Member
cashansa
Message 5 of 5 (509 Views)
09-02-2013 08:25 AM in reply to: cashansa
I think this option should be given high priority on the wish list, as you may have seen the comments from other ASD users on the effectiveness and speed of the steel module.
Regards
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
