AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
How to change lineweight of profile/plate on generated drawing
2 REPLIES 2
794 Views, 2 Replies
In dimension style settings dialog I see possibilitied to change lines properties for "Invisible edges", "Axes" or "User parts". But what about lines of profiles themselves? How to change them? By now I found a way to do it only using default lineweight of all lines. But in this case lineweight is changed also for elements where it is not necessary...
2 REPLIES 2
up, same situation
I change my lineweight in the layers properties. All layers associated with a particular view will begin with "xx____" and the blank spot is your group/assembly name. For example, I have a group named "TopView". The layer's name will begin with"xxTopView_Drawing_....." and there will be several for that group. Try changing these layers' lineweights and see if that helps.
”Boost
”Tips
