How do you specify a gap / spacing in back to back double Angle profiles? I am drawing diagonal bracing with a plate connection, but thus far haven't figured out to specify a 1/2" or 3/8" gap between the back to back angles.
Geoff
Solved by Geoff. Go to Solution.
I found the answer myself - Select the Compound Profiles Icon under Elements. Select both an initial and final point. Then you are prompted to select certain choices, one of which is back to back angles. From that you can select the orientation of the angles and the gap in-between.
Geoff
