AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Hidden lines error
1 REPLY 1
697 Views, 1 Reply
Hidden lines error
Hi, I have a problem with the hidden lines of some profiles.
I have attached an example that shows the error in the Layout called Sheet 1.
There are some profiles with the same position assigned. Some show the hidden lines perfectly, but others do not.
Do you know why?
Thanks in advance.
1 REPLY 1
I test ASD with a simple structure, only 6 beams.
Look at the results at the screenshot! The hidden lines of the two short beams at the bottom are missing.
I made exactly the same steps in each file:
  • Draw and copy the profiles
  • Create a group called 'marco'
  • Attach a document to the group
The differences between each file are that I use in:
  1. Original Template + Original Profile's Databases
  2. Modified Template + Modified Profile's Databases
  3. Original Template + Modified Profile's Databases
Any suggestion on how to correct this issue???
Thanks in advance!
”Boost
”Tips
