• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    New Member
    Grating using Plate command
    293 Views, 1 Replies
    08-15-2008 08:51 AM
    Is there a way I can trim back the plate (grating) to contour steel members. Is the plate command smart enough to detect steel, pipe and be able to contour around the objects? For example a Petro-Chemical platform
    Please use plain text.
    New Member
    Re: Grating using Plate command
    08-22-2008 04:24 AM in reply to: Msolis89
    Hello
    Use command "fit to object" (fourth icon in "Machining I" toolbar).
    In the dialog box you'll be able to set different variants of gap size and shape.
    regards
    Michał Koprowski
    Lead Product Designer
    michal.koprowski@autodesk.com
