AutoCAD Structural Detailing General DIscussion
Distinguished Contributor
markhubrich
Message 1 of 5 (1,641 Views)
Grating Weight Calculation
1641 Views, 4 Replies
02-16-2013 06:12 AM
How the heck is the weights calculated for grating?
For example:
I'm using a 15-DT-4 with 1 1/2" x 3/16 bars.
Per the product load tables, it weighs 13.82 pounds per sq. foot.
The "Self-weight/m2" I need to use to make it properly show the square foot weight is 0.096.
Later if I modify the properties of a peice of grate, this shows up as 1/8"
Can this be fixed?
I have to make a dummy 12x12 pc. of grate and mess around till the weight shows proper in a BOM.
It is almost as if when using Imperial units, some features are still using Metric.
markhubrich
Message 2 of 5 (1,582 Views)
Re: Grating Weight Calculation
02-20-2013 07:56 AM in reply to: markhubrich
Here is a grate 12"x12"
Monkey around to get the proper weight value for a material list
Go back and modify
The self weight now says 1/8".
It just doesn't make sense. .096 is not 1/8" let alone a dimension compared to a weight?
Please someone explain what "Unit (lb/ft) really means. This is a one square foot peice of grate. The manufacturer spec is 13.82 pounds per square foot. I am using RBCS-01.dwt. My units are set as Architectural with 1/16" precision.
Next blunder is the length.
Grate length is determined by the gearing bar direction. Grate is manufactured typically in 36" width and the bearing bar direction is the length. I get mine at 20 foot.
If I rotate the bearing bar direction, the length remains the same.
Valued Contributor
tedmail
Message 3 of 5 (1,500 Views)
02-27-2013 10:43 AM in reply to: markhubrich
Thanks for taking the time to make that so clear!  I have hated that problem.  I finally gave up on adding it to BOM because it was throwing off the total weight of a platform.
But, I agree!  This one should be easily fixed and done soon!!!!
markhubrich
Message 4 of 5 (1,498 Views)
02-27-2013 01:38 PM in reply to: tedmail
I recieved feedback from Autodesk on this. To make a long story short, the value that needs to go into the weight box is pounds per square inch for Imperial units.
I have another post about the length issues. That one makes me angry. I guess they see having the correct length on grate as a feature.
Valued Contributor
tedmail
Message 5 of 5 (1,368 Views)
03-08-2013 04:17 PM in reply to: markhubrich
They need to clean that interface up...
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
