i genrated a 3D drawing. But the position of the bolts isnt correct. in the 3D modell is everything in the right position. See picture 1 and 2. Do anyone knew this problem? has anyone a solution?
ASD 2012 - SP4
What have you already tried to do to fix it? If you haven't already, I'd recommend using the "Remove Bolt" tool and then putting the bolts back in. Also, possibly try the "regen" command. And make sure none of your views (in the "Position" tab of the Object Inspector) have the red line across them indicating they're out of date.
And, as always, there should be the obligatory closing and re-opening of ASD.
i tried every suggestions that you have listed.
Also i tried to generat only a little part of the stair; in this case the bolts of the steps and the automatic connections are correct. The bolts of the baseplate are in the right position but they are aligned in the wrong direction, they look up.
If i change the direction in the bolt options it makes no difference.
