AutoCAD Structural Detailing General DIscussion
iegia
Message 1 of 6 (1,443 Views)
From ASD to TEKLA
1443 Views, 5 Replies
05-08-2012 07:33 AM
How can I export a model from ASD 2013 to TEKLA?. I have tried export DSTV (CIS/2 and DSTV) and it does not work.
Valued Contributor
HulelaG
Message 2 of 6 (1,438 Views)
Re: From ASD to TEKLA
05-08-2012 08:11 AM in reply to: iegia
Good day,
Have you tried exoprting the file through ACIS and open in AutoCAD, then export to sat. format using your AutoCAD Standard?
Import the sat file into Tekla as solid body.
note that you will lose the Structural intelligence of ASD.
or Export to Robot then import to Tekla.
I am also looking for that method of Bringing the Tekla or Strucad file to ASD or Autocad  not as solid body.
iegia
Message 3 of 6 (1,433 Views)
05-08-2012 08:39 AM in reply to: HulelaG
Thanks, but there is some chance of not losing all the structural information?
iegia
Message 4 of 6 (1,424 Views)
05-08-2012 09:27 AM in reply to: iegia
Are there any recommendations for exporting the model to CIS / 2? For example disable the connection layer, avoiding curved profiles ..
Product Support
jad.dellel
Message 5 of 6 (1,384 Views)
05-11-2012 07:24 AM in reply to: iegia
You can try to export first your model to Revit and after use the free Tekla application to import it from Revit.
this link could help: http://www.tekla.com/international/solutions/building-construction/Pages/export-revit-tekla-structur...
Jad DELLEL
Structural Engineering Support Autodesk, Inc.
Valued Mentor
Rich.O.3d
Message 6 of 6 (1,146 Views)
10-16-2012 04:36 PM in reply to: iegia
When the cis/2 export creates the sat file, it ignores the profile offsets from the 'profile properties' dialogue box and 'moves' the member to be centred about its insertion line.
Is there a known work around or somwhere i can access cis/2 export options.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
