• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    Member
    From ASD to TEKLA
    828 Views, 5 Replies
    05-08-2012 07:33 AM
    How can I export a model from ASD 2013 to TEKLA?. I have tried export DSTV (CIS/2 and DSTV) and it does not work.
    Please use plain text.
    Valued Contributor
    HulelaG
    Re: From ASD to TEKLA
    05-08-2012 08:11 AM in reply to: iegia
    Good day,
    Have you tried exoprting the file through ACIS and open in AutoCAD, then export to sat. format using your AutoCAD Standard?
    Import the sat file into Tekla as solid body.
    note that you will lose the Structural intelligence of ASD.
    or Export to Robot then import to Tekla.
    I am also looking for that method of Bringing the Tekla or Strucad file to ASD or Autocad  not as solid body.
    Member
    05-08-2012 08:39 AM in reply to: HulelaG
    Thanks, but there is some chance of not losing all the structural information?
    Member
    05-08-2012 09:27 AM in reply to: iegia
    Are there any recommendations for exporting the model to CIS / 2? For example disable the connection layer, avoiding curved profiles ..
    Product Support
    jad.dellel
    05-11-2012 07:24 AM in reply to: iegia
    You can try to export first your model to Revit and after use the free Tekla application to import it from Revit.
    this link could help: http://www.tekla.com/international/solutions/building-construction/Pages/export-revit-tekla-structur...
    Jad DELLEL
    Structural Engineering Product Support Autodesk, Inc.
    Valued Mentor
    Rich.O.3d
    10-16-2012 04:36 PM in reply to: iegia
    When the cis/2 export creates the sat file, it ignores the profile offsets from the 'profile properties' dialogue box and 'moves' the member to be centred about its insertion line.
    Is there a known work around or somwhere i can access cis/2 export options.
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
