• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    Valued Contributor
    tedmail
    From ASD to BIM?
    912 Views, 5 Replies
    07-09-2011 07:19 AM
    Any way of doing this?  I got comfertable modeling in ASD and forgot to go use Revit, and now I can't find a way to export it.
    Please use plain text.
    Member
    BarryHaugen41
    Re: From ASD to BIM?
    07-13-2011 10:41 AM in reply to: tedmail
    There is a couple of ways of doing this, first one is to use the revit extension for ASD, the only problem with that is only columns and beams come across. No connections or cuts come with the export. The second way is to export as ACIS solid model and bring that as an underlay into revit, you will loose the profile sizes but all the components will be there.
    Valued Contributor
    07-24-2011 11:44 PM in reply to: tedmail
    USE CIS/2 format (See pic)
    CIS/2 is similar to IFC but used only for steel.
    For example Tekla reads CIS/2
    Revit reads only main profiles from CIS/2
    If it is needed for visual , use ACIS Solids.
    ____________________________________________
    If you find my post useful give me Kudos. Thank you!
    If my post solved your problem, accept it as a solution.
    Valued Mentor
    Rich.O.3d
    Re: From ASD to BIM?....not realy...there is a BUG
    10-16-2012 06:08 PM in reply to: Priitl220
    that would work if there wasnt a BUG
    cardinal points are ignored when the CIS/2 is exported
    ie if you have your insertion line at TOS, then all your members will jump up so that the steel member profile is located with the centroid of section at TOS (all your steel will be half the member depth higher than it should be
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Valued Contributor
    markhubrich
    10-17-2012 09:51 AM in reply to: Rich.O.3d
    Try the Navisworks export. 'NWCOUT' command. What software will be working with the model after you export it? Every single BIM job I've done was required to provide model files compatable with Navisworks Manage. NWC files are extremely small in file size as well. Nice for emailing.
    Mark
    Valued Mentor
    Rich.O.3d
    10-18-2012 02:58 PM in reply to: markhubrich
    you cant imprort navis cache files into other detailing programs
    nwcout does not create a CIS/2 (its a CIMsteel Integration Standards file, its a type of *.sat)
    Im exporting for sending to a detailer that uses Tekla, but the CIS/2 bug will still be evident when pushed into a BIM program hence the double post :smileywink:
    I would have used a different work flow from the start of the project if it was up to me.
    When given lemons, I try to make lemonade :smileyvery-happy:
    I was commenting on the bug in the autodesk version of this output, I can turn navis pretty much inside out, but thanks for the suggestion.
    CAD Management 101:
