I have the following problem: I define my foundation as a solid and then I make the formwork from it. After that I create bottom reinforcement and distribute it in the foundation. When I create a section cut trough the formwork and the distributed reinforcement something unexpected appears: the defined reinforcement must be at the same level in that newly created section cut, but it isn't. Please see the attached files.
Thank you in advance.
St.Stefanov
