I want to ask the developers of ASD few qustions (if they can answer):
1.When we will be able to see bolts in 2d drawings ?(no need date only if this option is on agenda to develop) :))
2.When we will be able to see "naighboring parts" in assembly drawings ? (this will reduce the groups in model)
3.Why clipping plane works only in 2d wireframe and this comand is not working in realistic view, conceptual etc, and why not some day when we define cliping plane then we can define this view in 2d deawings?
4.Why we can't define the view plane from which we can define the view depth in front and behind this view plane in 2d dwawings?
Thanks in advance
Best regards
@ZHUKOV_ING wrote:I want to ask the developers of ASD few qustions (if they can answer):
1. You can create plane view from a 3D assembly. The bolts are visible.
2. There is an option to set the depth of the view in "Dimensioning style settings"->"Depth". You can use % or absolute units.
