• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Error importing CIS/2 file from revit
    282 Views, 4 Replies
    04-15-2009 06:00 PM
    Hi to all,
    The error ocurre when the elements in revit do not have the same description as the ASD data base. Those elemente do not get imported :-(. A workarround will be to create from ASD the elements that I will use in my project . . then export this elements to revit as cis then I can have acces to the same properties in the revit file . . . here come the bad thing . . . then I just have to re-aply the element sizes . . . to much work . . there must be a work arround . . . thanks for the help
    Carlos
    Please use plain text.
    Valued Contributor
    Re: Error importing CIS/2 file from revit
    04-16-2009 12:02 AM in reply to: RamonRUIZ4494
    You have to first update ASD. Open ASD go in file menu/Steel/Project Preferences/Profiles/click inverted T shape for adding AISC shape/OK.
    Now you can import your file & there will be no error.
    Suresh
    04-16-2009 08:43 AM in reply to: RamonRUIZ4494
    Thank yoou Suresh for the solution
    Best Regards,
    Carlos
    New Member
    05-08-2009 08:35 AM in reply to: RamonRUIZ4494
    There is now a Google group to discuss CIS/2.
    http://groups.google.com/group/cis2-group
    Bob Lipman
    http://cic.nist.gov/lipman/
    Valued Contributor
    05-09-2009 06:58 AM in reply to: RamonRUIZ4494
    This was needed and I am exicted.
    Thanks once again,
    Suresh
