AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Drawing Orientation
2 REPLIES 2
derrick.lambrecht
845 Views, 2 Replies
Drawing Orientation
When detailing parts and assemblies, it seems to have switched the part orientation. Using the world coordinates for both the part postition and the assembly postition, it appears the assembly postition was rotated by 180 degrees. Why does this happen? If using world coordindates for both, should they both be the same orienatation? Please find the attached PDF.
2 REPLIES 2
selmir
in reply to: derrick.lambrecht
Does anyone have an aswer for this? My drawing is showing the reverse side of my assembly and I cant figure out how to change the orientation.
Jianna
in reply to: selmir
Have you tried changing the coordinate system of the part? Right click on your piece mark in the "Positions" tab of the object inspector, then click "Change coordinate system".
See attached screenshot.
”Boost
”Tips
