AutoCAD Structural Detailing General DIscussion
Active Contributor
Delvin.Ramassami
Message 1 of 4 (383 Views)
Drawing No
383 Views, 3 Replies
04-07-2013 11:13 PM
How can add drawing No with reference to the beam or column position for manufacturing drawing ?
For Example :- Beam (B28)
                        Drawing No B28
Valued Contributor
HulelaG
Message 2 of 4 (367 Views)
Re: Drawing No
04-08-2013 12:52 AM in reply to: Delvin.Ramassami
Best of my knowledge on ASD is, when you apply variable Var_pos,  and Var Part. it should pick up the Drawing or Assembly number.
take note this doesnt work when you generate drawings of Assembly with multiple parts in one drawing, Make Single assembly and have parts arranged in separate drawing.
Active Contributor
Delvin.Ramassami
Message 3 of 4 (285 Views)
Re: Drawing No
04-22-2013 09:34 PM in reply to: HulelaG
There a way of doing it :
While creating your template
- insert an MTEXT
- insert Field
Field Category (Others)
- System variable
Select Ctab to reference the position name of the sheet
Active Contributor
Delvin.Ramassami
Message 4 of 4 (281 Views)
Re: Drawing No
04-22-2013 09:37 PM in reply to: Delvin.Ramassami
Its more worth when inserting in a Template at first
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
