AutoCAD Structural Detailing General
rinku.yadav
Message 1 of 7 (441 Views)
Database
441 Views, 6 Replies
05-12-2012 03:32 AM
hi dear
I just want to add some rectangular column database in the ASD, is  there any way so that i can use any excel data import in the ASD FOR THE column data base?
Help would be appriciated.
Regards
Rinku Yadav
Valued Contributor
tedmail
Message 2 of 7 (397 Views)
Re: Database
06-06-2012 10:12 AM in reply to: rinku.yadav
There is currently no way to manipulate the database that I have seen, however you can create your own profiles and name them as you wish and save them in subgroups and such.
Distinguished Contributor
CristianLANCULESCU1367
Message 3 of 7 (384 Views)
Re: Database
06-08-2012 05:48 AM in reply to: tedmail
Do you have any tutorial/document to learn how to make your own profiles and add them?
Valued Contributor
tedmail
Message 4 of 7 (368 Views)
Re: Database
06-12-2012 10:43 AM in reply to: CristianLANCULESCU1367
I have had the best success creating a REGION of the profile complete with all hollowed sections already subtracted.  Then select the create user profile button and select the region.  Make sure you have the naming correct when creating as there is no way to manipulate the database.  You can't rename, delete, modify or update the profile.  Any change to it will require a new name.
Hope that helps.
Ted
Message 5 of 7 (351 Views)
Re: Database
06-14-2012 01:16 AM in reply to: tedmail
Thank you.
I thought we could manipulate the database in a DB editor.
markhubrich
Message 6 of 7 (288 Views)
Re: Database
07-10-2012 12:37 PM in reply to: CristianLANCULESCU1367
I had actually gone as far as "replacing" members in the xml files. I had to do this to get some stainless grades also.
If you try this, make a backup of the xml files first :smileyhappy:
Message 7 of 7 (275 Views)
Re: Database
07-12-2012 05:55 AM in reply to: markhubrich
What interest me is to modify a section name (e.g.: TCAR to Tv)
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
