AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Custom Bolts in Structural Detailing
3 REPLIES 3
1292 Views, 3 Replies
Hi!
In ASD 2010 it was possible to modify the BoltsGradeList.mdb or any other mdb-s in the same folder, thus add a custom grade bolt etc. to the list and later that could be choosen in the connection wizard. Can it be done in 2011? I only found xml files and modifying them seemd to have no influence to the program. So if yes wich file should i modify? ( what is the default location for it?)
Levente
3 REPLIES 3
I have just modified this and it works good
C:\ProgramData\Autodesk\Structural\Common Data\2011\Data\Conn\BoltGradeList.xml
octavian_ct
Hi
For ALL databases you can use Robot Software, even trial version. It can acces mdb files and modifies.
Succes
Tony_Gibbs
Are you still having a problem here??
”Boost
”Tips
