• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    New Member
    TLevente
    Custom Bolts in Structural Detailing
    828 Views, 3 Replies
    08-30-2010 07:35 AM
    Hi!
    In ASD 2010 it was possible to modify the BoltsGradeList.mdb or any other mdb-s in the same folder, thus add a custom grade bolt etc. to the list and later that could be choosen in the connection wizard. Can it be done in 2011? I only found xml files and modifying them seemd to have no influence to the program. So if yes wich file should i modify? ( what is the default location for it?)
    Levente
    Please use plain text.
    Active Member
    ASDatTAFE
    Re: Custom Bolts in Structural Detailing
    01-21-2011 05:37 AM in reply to: TLevente
    I have just modified this and it works good
    C:\ProgramData\Autodesk\Structural\Common Data\2011\Data\Conn\BoltGradeList.xml
    Active Member
    02-04-2011 08:06 AM in reply to: TLevente
    Hi
    For ALL databases you can use Robot Software, even trial version. It can acces mdb files and modifies.
    Succes
    Valued Contributor
    tony
    02-08-2011 07:09 PM in reply to: TLevente
    Are you still having a problem here??
