• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Member
    Criteria of Connections?
    744 Views, 7 Replies
    10-18-2010 01:16 AM
    I'm trying to do a two beams to column web connection, but when I select the relevant beams and column it tells me,  “Selected profiles does not meet criteria of this type of connection”. The beams are Universal Beams and the column is a Universal Column, so there's no reason why it SHOULDN'T work.
    Is there a document anywhere stating what the "criteria" is?
    Please use plain text.
    Member
    Re: Criteria of Connections?
    07-22-2012 05:47 AM in reply to: danielledew
    i have the same problem
    07-23-2012 02:09 PM in reply to: danielledew
    I've tested this out a couple times, without any problems yet.  Could you post up a screen shot or two of your current structure so I can more accurately duplicate it?
    To my knowledge, I don't believe there is any criteria published beyond what is in the description.
    Kyle Pope
    Process and Power Specialist
    ECAD, Inc
    Our Blog
    www.pdoteam.com
    Product Support
    Jakub.Brozonowicz
    07-24-2012 06:40 AM in reply to: kylepope
    Maybe the angle between members is that criteria which accurately is not passed.
    I'm able to answer (not guessing only) with true model sample.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    07-26-2012 01:24 AM in reply to: M_Azab
    i faced this prolem when i use the connection column to rafter as shown in attached photo
    Product Support
    Jakub.Brozonowicz
    07-26-2012 03:43 AM in reply to: M_Azab
    To make this connection possible to make due to such criteria you need to rotate column by 90deg.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    07-26-2012 04:59 AM in reply to: Jakub.Brozonowicz
    the column and rafter have the same section therefore no need to rotate it
    Valued Contributor
    CristianLANCULESCU1367
    07-30-2012 07:11 AM in reply to: danielledew
    danielledew wrote:
    I'm trying to do a two beams to column WEB connection, but when I select the relevant beams and column it tells me,  “Selected profiles does not meet criteria of this type of connection”. The beams are Universal Beams and the column is a Universal Column, so there's no reason why it SHOULDN'T work.
     The beam web is parallel to the column's web. That's why it doesn't work.
