• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Member
    Accepted Solution
    Creating profile of my desired size and shape like RHS 1200*500*25 in ASD
    638 Views, 10 Replies
    01-28-2013 09:20 AM
    I need to create some profiles which are not in the given profile list of ASD, such as, RHS 1200*500*25, W 600*300*25 etc . Is that possible? If so, how? If i use my defined sections, then woyld there be any problem in assigning the joints/connections in ASD?
    I really need some quick suggestions.
    S. M. Shafin Hasan
    Please use plain text.
    Active Contributor
    Re: Creating profile of my desired size and shape like RHS 1200*500*25 in ASD
    01-28-2013 09:44 AM in reply to: shafin_42
    Make Region and save User Sections
    Active Member
    01-29-2013 03:23 AM in reply to: zcsillag
    It worked, thanks a lot zcsillag.
    How can I solve the problems in assigning the connections? For almost all connections with RHS sections, it says, "Selected profiles does not meet criteria of this type of connection". Is there any way to create user defined connections?
    Active Contributor
    01-29-2013 04:32 AM in reply to: shafin_42
    Valued Contributor
    01-29-2013 04:47 AM in reply to: shafin_42
    ASD can't create custom connections. The most you can do is to "modify" an automatic connection.
    Active Member
    Why there is no mass or thickness of user defined sections?
    01-30-2013 05:53 AM in reply to: shafin_42
    I have noticed that mass and thickness tf is zero in profile properties. I have attached an image regarding the issue. Is there any way to add mass or thickness to profile?
    S. M. Shafin Hasan
    Valued Contributor
    tony
    Re: Why there is no mass or thickness of user defined sections?
    01-30-2013 12:43 PM in reply to: shafin_42
    Yes you can do this easily if you know how to edit the xml file that holds the catalogue entry you made for the rhs
    tonyp
    Active Member
    01-31-2013 01:40 AM in reply to: tony
    I have found the profile database in C:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Prof\ Aiscpro.xml, but after openning that file, I couldnt find the profile I assigned and saved as user profile in AISC database. Can you help where/how can I find that database?
    Active Member
    03-05-2013 10:44 AM in reply to: shafin_42
    I'm using windows 7 and here is where I found the information on user sections after I made them:
    C:\Users\"User Name"\AppData\Roaming\Autodesk\Structural\Common Data\2013\"DATABASE NAME"PRO.XML
    Valued Contributor
    tony
    03-05-2013 01:36 PM in reply to: shafin_42
    I use a program called "XML Notepad" to edit my XML files
    My user sections are saved to a file called
    C:\Users\UserName\AppData\Roaming\Autodesk\Structural\CommonData\2013\RUSERPRO.XML.
    You will have to look through the profiles you have created to find the right one.
    Notice in the attachment  there is a RED DOT entry for "MASS" just enter the weight here and so on
    I hope this helps. If not let me know the details of the section you need to create and I will send you an XML file
    Regards
    Tony
