AutoCAD Structural Detailing General
Active Member
shafin_42
Message 1 of 11 (1,422 Views)
Creating profile of my desired size and shape like RHS 1200*500*25 in ASD
1422 Views, 10 Replies
01-28-2013 09:20 AM
I need to create some profiles which are not in the given profile list of ASD, such as, RHS 1200*500*25, W 600*300*25 etc . Is that possible? If so, how? If i use my defined sections, then woyld there be any problem in assigning the joints/connections in ASD?
I really need some quick suggestions.
S. M. Shafin Hasan
zcsillag
Message 2 of 11 (1,418 Views)
Re: Creating profile of my desired size and shape like RHS 1200*500*25 in ASD
01-28-2013 09:44 AM in reply to: shafin_42
Make Region and save User Sections
Regards
Csillag Zoltán
Active Member
shafin_42
Message 3 of 11 (1,387 Views)
01-29-2013 03:23 AM in reply to: zcsillag
It worked, thanks a lot zcsillag.
How can I solve the problems in assigning the connections? For almost all connections with RHS sections, it says, "Selected profiles does not meet criteria of this type of connection". Is there any way to create user defined connections?
zcsillag
Message 4 of 11 (1,381 Views)
01-29-2013 04:32 AM in reply to: shafin_42
Regards
Csillag Zoltán
Valued Contributor
lucis29
Message 5 of 11 (1,372 Views)
01-29-2013 04:47 AM in reply to: shafin_42
ASD can't create custom connections. The most you can do is to "modify" an automatic connection.
Active Member
shafin_42
Message 6 of 11 (1,349 Views)
Why there is no mass or thickness of user defined sections?
01-30-2013 05:53 AM in reply to: shafin_42
I have noticed that mass and thickness tf is zero in profile properties. I have attached an image regarding the issue. Is there any way to add mass or thickness to profile?
S. M. Shafin Hasan
Valued Contributor
tony
Message 7 of 11 (1,333 Views)
Re: Why there is no mass or thickness of user defined sections?
01-30-2013 12:43 PM in reply to: shafin_42
Yes you can do this easily if you know how to edit the xml file that holds the catalogue entry you made for the rhs
tonyp
Active Member
shafin_42
Message 8 of 11 (1,320 Views)
01-31-2013 01:40 AM in reply to: tony
I have found the profile database in C:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Prof\ Aiscpro.xml, but after openning that file, I couldnt find the profile I assigned and saved as user profile in AISC database. Can you help where/how can I find that database?
Active Member
aaron.simpson
Message 9 of 11 (1,106 Views)
03-05-2013 10:44 AM in reply to: shafin_42
I'm using windows 7 and here is where I found the information on user sections after I made them:
C:\Users\"User Name"\AppData\Roaming\Autodesk\Structural\Common Data\2013\"DATABASE NAME"PRO.XML
Valued Contributor
tony
Message 10 of 11 (1,091 Views)
03-05-2013 01:36 PM in reply to: shafin_42
I use a program called "XML Notepad" to edit my XML files
My user sections are saved to a file called
C:\Users\UserName\AppData\Roaming\Autodesk\Structural\CommonData\2013\RUSERPRO.XML.
You will have to look through the profiles you have created to find the right one.
Notice in the attachment  there is a RED DOT entry for "MASS" just enter the weight here and so on
I hope this helps. If not let me know the details of the section you need to create and I will send you an XML file
Regards
Tony
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
