AutoCAD Structural Detailing General
Active Contributor
emmar0001
Message 1 of 3 (231 Views)
Creating a workframe model with lines
231 Views, 2 Replies
02-22-2014 06:35 PM
I have a heavy background in AutoCAd and need to model a fairly complex (non-orthogonal) steel frame using ASD. I would prefer to draw the frame in ASD using lines and then create the workframe around this. Is this possible?
Alternatively, can i draft the stick diagram of the frame in AutoCAD and then import into ASD?
C3D 2010
Intel Core 2, Windows XP
2.67GHz, 3GB RAM
Member
CianG
Message 2 of 3 (214 Views)
Re: Creating a workframe model with lines
02-23-2014 02:59 PM in reply to: emmar0001
Yes you can insert the members via: Insert by 2 points / Insert by line / Insert by point
Active Contributor
JannieHunter
Message 3 of 3 (183 Views)
02-28-2014 05:09 AM in reply to: CianG
A workframe isn't required, its just a tool to make things a bit easier
Draw framework with lines and just delete them afterwords
Jannie Hunter
Modena Design Centres
South Africa
011 463 1553
You are not logged in.
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
