AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Creating a workframe model with lines
2 REPLIES 2
emmar0001
511 Views, 2 Replies
I have a heavy background in AutoCAd and need to model a fairly complex (non-orthogonal) steel frame using ASD. I would prefer to draw the frame in ASD using lines and then create the workframe around this. Is this possible?
Alternatively, can i draft the stick diagram of the frame in AutoCAD and then import into ASD?
C3D 2010
Intel Core 2, Windows XP
2.67GHz, 3GB RAM
2 REPLIES 2
CianG
in reply to: emmar0001
Yes you can insert the members via: Insert by 2 points / Insert by line / Insert by point
JannieHunter
in reply to: CianG
A workframe isn't required, its just a tool to make things a bit easier
Draw framework with lines and just delete them afterwords
Jannie Hunter
Modena Design Centres
South Africa
011 463 1553
”Boost
”Tips
