• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    New Member
    EddieOBrien4224
    Creating a knee barce in ASD 2012
    688 Views, 1 Replies
    09-23-2011 09:41 PM
    Hi there,
    I was hoping someone may be able to help me to create a knee brace say to be used as a pipe support.
    The arrangement is along the lines of using an existing UC (H Section) as a column. I am then attaching a horizontal member *200 PFC (Channel section) say about 1000mm LG to the flange of the column using a web side plate (shear plate). To support the  horizontal member I am trying to fit a strut (say 75x75x6 EA (angle section) ) at 45 degrees, to support the horitontal member off the column.
    I have spent hours and hours trying to find a way in ASD...any ideas or direction?
    regrads
    Eddie O'Brien
    Please use plain text.
    New Member
    EddieOBrien4224
    Re: Creating a knee brace in ASD 2012
    09-26-2011 12:10 AM in reply to: EddieOBrien4224
    Well
    the brains trust has failed me........however I have worked it out myself
    I drew two columns and brace line between each column, with a horizontal member between the column (strut).
    I then used the bracing command.....using the strut as a vertical limitation. Now I had a single brace beetwn one column and the strut. I then selected each of the columns that I drew and "hid" them.
    This gives me a knee brace off an "existing" column to support my pipework.
    Eddie O'Brien
