AutoCAD Structural Detailing General
benniebadenhorst
Message 1 of 3 (314 Views)
Connection ignore weld on one rib
314 Views, 2 Replies
09-27-2012 01:45 AM
Hi
Im using the macro ' End plate- Beam/beam with rib. Every time the one rib does not get welded to the main beam. It isnt always the same rib that gets neglected, sometimes the one on the connection side, other times the one on the back side.
On the attached picture it is the rib on the connection side.
Any idea why this is happening?
Valued Contributor
lucis29
Message 2 of 3 (276 Views)
Re: Connection ignore weld on one rib
10-01-2012 11:30 PM in reply to: benniebadenhorst
Maybe is just a view glitch. Try Regen very close to the Connection.
Try to create a group from the Connection Elements, add a Drawing and see if it can recognize the weld. If not, that's a problem.
benniebadenhorst
Message 3 of 3 (273 Views)
10-01-2012 11:57 PM in reply to: lucis29
Hi
It is not just a view glitch. I detetmined that he one rib actually penetrate the main beam, and that is why the weld is not created. It is still odd that the automatic connection does not fit the rib to the beam correctly.
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
