• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    petko666
    Change of plate UCS ?
    143 Views, 5 Replies
    03-24-2012 07:26 AM
    Is it possible to change the UCS of a plate in ASD 2012 ?
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: Change of plate UCS ?
    03-28-2012 07:38 AM in reply to: petko666
    Dynamic UCS from Tools?
    What exaclty change you mean?
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    petko666
    03-28-2012 07:54 AM in reply to: petko666
    Well , every plate has its own coordinate system . I want to change this system for existing plates .
    Product Support
    Jakub.Brozonowicz
    03-29-2012 04:16 AM in reply to: petko666
    No way to do that.
    This LCS is integrated with sizes.
    You determine it during insertion.
    After that if you want to rotate only LCS two actions have to be made:
    1. replace W with L size
    2. rotate the plate around local 0,0.
    Of course it isn't perfect solution itself.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    petko666
    03-29-2012 06:22 AM in reply to: Jakub.Brozonowicz
    Yes , I did something similar . I set in the settings the local plate axes to be shown , and then made new plate with the same contour until I got the axes I need . I just wished there wes some way to do this automatically .
    Product Support
    Jakub.Brozonowicz
    03-29-2012 06:38 AM in reply to: petko666
    As mentioned before, unfortunately no.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
