AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
CHANGES IN A WORKFRAME
1 REPLY 1
jorge.lopera
540 Views, 1 Reply
Hi, i am testing ADSD2009, When I use the predefined workframe such a box, I put the profiles without problem, then If I modify the Box workframe, I can't finde the update command, or with this predefined workframes I cannot update any changes to the profiles?
In another words, the wire frame that we can insert, and using for insert profiles is parametric?
Technical Specialist
Nexsys de Colombia
1 REPLY 1
justin
in reply to: jorge.lopera
When you create a box it is created and you cant update it when you edit the parameters.
You going to have to create a new box, or edit the existing one.
”Boost
”Tips
