• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    Valued Contributor
    Bug in ASD 2013
    252 Views, 3 Replies
    06-01-2012 01:47 PM
    I am reporting one bug that i notice after releasing the sowtware: When i select some asd object and try to change the color then color meny is disapearing and color of the elemet remains unchanged see video:  http://www.screencast.com/t/MrjMVxijap
    One more thing that i notice yesterday, when i start wit generating the drawings then saving the model was very very long.
    Please use plain text.
    petko666
    Re: Bug in ASD 2013
    06-02-2012 01:20 AM in reply to: ZHUKOV_ING
    It's not only the color , the same happens if you try changing linetype , or lineweight . But if you change it and then draw the element , you can use matchprop to change the others you want to change . It's a workaround , but the bug is annoying and needs fixing .
    Valued Contributor
    CristianLANCULESCU1367
    Re: Bug in ASD 2013
    06-08-2012 05:04 AM in reply to: ZHUKOV_ING
    Same here. What about ACAD vanilla? Same bug?
    Product Support
    Re: Bug in ASD 2013
    06-11-2012 07:39 AM in reply to: CristianLANCULESCU1367
    These eeffects are  not observed when using "classic" workspaces:
    It is also not observed on "vanilla" AutoCAD started using "AutoCAD" profile instead of "AutoCAD Structural Detailing" profile.
    It is forwarded to development team to be investigated.
    Pawel Pulak
    Support Specialist
    Product Support
