AutoCAD Structural Detailing General DIscussion
filipberggren
Message 1 of 5 (830 Views)
Bill of Material generation scaling problems
830 Views, 4 Replies
02-25-2013 05:10 AM
Have had this problem for a while, but i have solved it by copying the model to a file i know the BoM generation works but now i want to fix it for a new project.
The problem is, when adding a BoM table in the automatic drawing choices, my table scales down the letters to about 1/10 of the "correct size". I have not changed any settings for this, but now when i do want to change it I cant seem to find the options for this.
It seems like i am not finding the correct options, does anyone know where to make these changes so my tables can look normal and actually be useful? I have attached two PS.
Thanks in advance.
/Filip
RedNova
Message 2 of 5 (808 Views)
Re: Bill of Material generation scaling problems
02-25-2013 06:39 AM in reply to: filipberggren
Might be used alternative text style in the table. Try with standard one.
filipberggren
Message 3 of 5 (800 Views)
02-25-2013 07:01 AM in reply to: RedNova
Yes, i thought of that. Problem is, in the scrolldown window i cant choose rbcs_tab font, dont know why it has disapeared. Is there a way to change the settings for just tables styles back to default without changing everything back to default (dimension, description styles etc)?
Edit; I might clarify that clicking the "default" box in tables style does nothing as far as font or style "RBCS_tab".
RedNova
Message 4 of 5 (794 Views)
02-25-2013 07:10 AM in reply to: filipberggren
Is "RBCS_tab" text style lost from this file only?
If so, did you try to import (update) table style via ASD center from another file?
filipberggren
Message 5 of 5 (790 Views)
02-25-2013 07:18 AM in reply to: RedNova
Didnt know about that, but it seems to do the trick! Thanks, marking as solution.
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
