AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Bending A Plate
3 REPLIES 3
1607 Views, 3 Replies
Bending A Plate
Hello every one I need help on bending a plate  I keep on getting the same message eventhough I change the ucs view
Here is how I do it :
Command: '_-view Enter an option
[?/Delete/Orthographic/Restore/Save/sEttings/Window]: _right Regenerating model.
Command: 3do
3DORBIT Press ESC or ENTER to exit, or right-click to display shortcut-menu.
Regenerating model.
Command: _RBCS_bentplate
Select plate(s) :1 found
Select plate(s) : Choose method [by2points/byLine]<by2points>:L
Select line: Location of bending line[Center/Edge] <Center>
Specify internal radius or [Axial] <0.125000>:
Specify angle <90.000000>
Pick side to be wrapped :
*** Cut plane does not intersect selected part #1 ***
I changed the view to all views to WORLD, TOP, BOTTOM, LEFT RIGHT, FRONT & BACK  but the error is always the same :  *** Cut plane does not intersect selected part #1 ***
Thank you very Much
PEDRO E
3 REPLIES 3
Jakub.Brozonowicz
Could you pleae share the file with a plate to check?
Jakub Brożonowicz
Global Product Support
in reply to: Jakub.Brozonowicz
Here is the file of the bent plate I cant bend. the white lines are the bending point
tedmail
I assume it just doesn't work?  I get the same results as described and have not been able to bend the plate.
Actually, after finally playing around with it quite a bit, and knowing I tried these exact same steps before, I was able to get the bend done.  Things to take note of:
The Z coordinate should be perpendicular to the face of plate.
180 degree bend is actually not a bend at all, but keeping it flat.
The radious should be .1 and go up from there to get your desired bend.
But at least it gets the job done...
”Boost
”Tips
