AutoCAD Structural Detailing General DIscussion
Member
strlblr
Message 1 of 5 (411 Views)
Beam/Column Connections
411 Views, 4 Replies
09-07-2013 02:31 AM
For structural elements(members) created using "BEAM"/"COLUMN" in ASD-MODEL - we are not able to get "CONNECTIONS" such as shear plate/clip angle etc.,
zcsillag
Message 2 of 5 (363 Views)
Re: Beam/Column Connections
09-09-2013 10:54 AM in reply to: strlblr
Can uppload any pictures or file ?
Regards
Csillag Zoltán
Member
strlblr
Message 3 of 5 (346 Views)
09-09-2013 10:17 PM in reply to: zcsillag
Thanks for reply,
Please find the attachment :Frame.dwg ,where we are not able to achieve any coulmn beam connections using "connections"macro
zcsillag
Message 4 of 5 (329 Views)
09-10-2013 10:08 AM in reply to: strlblr
Hi !
Can't made any connection for plate compound assembly :smileyfrustrated:
Edit USER database and made profile, and u can use any connection macro !
User database -> c:\ProgramData\Autodesk\Structural\Common Data\2014\Data\Prof\Ruserpro.xml
Regards
Csillag
Regards
Csillag Zoltán
Member
strlblr
Message 5 of 5 (310 Views)
09-10-2013 10:35 PM in reply to: zcsillag
We have used "BEAM" element in ASD-Model to gererate columns and beams as shown in the previous attachment frame.dwg.  These generated beams are made up of PLATES(automatic generation by ASD).This is exactly the way built-up beams/columns fabricated.
As suggested by you , if we generate  beam using profile and use automatic positioning, bill of materials will have only one position mark(as a single beam) instead of three positoin marks(for three plated built-up beam). This is the reason  for trying to get connections for "BEAM" element (plate compound assembly).
strlblr
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
