AutoCAD Structural Detailing General
benniebadenhorst
Message 1 of 7 (943 Views)
Beam/Column Connection
943 Views, 6 Replies
07-09-2012 01:34 AM
I want to create a beam to column connection. There is identical beams on both sides of the column web. I see that you can create a double sided clip angle connection, but I was looking to create a double sided end plate connection. Is this possible? Any guidance would be appreciated.
Product Support
Jakub.Brozonowicz
Message 2 of 7 (936 Views)
Re: Beam/Column Connection
07-09-2012 06:49 AM in reply to: benniebadenhorst
Please look at movie here.
It might be a solution but not by one connection and no connection ability is kept for such solution unfortunately.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Distinguished Contributor
CristianLANCULESCU1367
Message 3 of 7 (920 Views)
07-10-2012 05:09 AM in reply to: benniebadenhorst
There is a macro that can do this. It is called "2beams to column web" which does exactly what you wannt.
@Jakub: Why would someone do that when there is a macro fo that?
Regards.
benniebadenhorst
Message 4 of 7 (917 Views)
07-10-2012 05:20 AM in reply to: CristianLANCULESCU1367
Thank you. That is why I asked. I couldnt think that they would not have this macro. And all this time I was looking under the wrong group of connections.:smileyhappy:
Product Support
Jakub.Brozonowicz
Message 5 of 7 (913 Views)
07-10-2012 06:03 AM in reply to: CristianLANCULESCU1367
True.
My oversight.
Thanks.
Jakub Brożonowicz
benniebadenhorst
Message 6 of 7 (804 Views)
09-26-2012 02:08 AM in reply to: Jakub.Brozonowicz
Does the suggested macro work if the beams are not the same size?
Valued Contributor
lucis29
Message 7 of 7 (738 Views)
10-01-2012 11:26 PM in reply to: benniebadenhorst
Yes.
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
