• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    benniebadenhorst
    Accepted Solution
    Beam/Column Connection
    699 Views, 6 Replies
    07-09-2012 01:34 AM
    I want to create a beam to column connection. There is identical beams on both sides of the column web. I see that you can create a double sided clip angle connection, but I was looking to create a double sided end plate connection. Is this possible? Any guidance would be appreciated.
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: Beam/Column Connection
    07-09-2012 06:49 AM in reply to: benniebadenhorst
    Please look at movie here.
    It might be a solution but not by one connection and no connection ability is kept for such solution unfortunately.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    CristianLANCULESCU1367
    07-10-2012 05:09 AM in reply to: benniebadenhorst
    There is a macro that can do this. It is called "2beams to column web" which does exactly what you wannt.
    @Jakub: Why would someone do that when there is a macro fo that?
    Regards.
    benniebadenhorst
    07-10-2012 05:20 AM in reply to: CristianLANCULESCU1367
    Thank you. That is why I asked. I couldnt think that they would not have this macro. And all this time I was looking under the wrong group of connections.:smileyhappy:
    Product Support
    Jakub.Brozonowicz
    07-10-2012 06:03 AM in reply to: CristianLANCULESCU1367
    True.
    My oversight.
    Thanks.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    benniebadenhorst
    09-26-2012 02:08 AM in reply to: Jakub.Brozonowicz
    Does the suggested macro work if the beams are not the same size?
    Valued Contributor
    10-01-2012 11:26 PM in reply to: benniebadenhorst
    Yes.
