I am having trouble keeping everything to scale between dimension styles and automatic drawing scales. What exactly needs to be set in order to have everything to come out at the correct scale? The only way I can get my text to come out at 1/8" is if i manualy change the height and take it off Annotative.
Thank You
ASD is based on an old version of AutoCad, when Annotative was not implemented. 🙂
I've tried using a style made with Annotative, but it shows wrong.
Advice: Keep the default Text Style, and it should scale it right.
