AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Audit could not correct errors in database
6 REPLIES 6
tpham2001
11241 Views, 6 Replies
Hi All,
I was looking forward to a good start for Monday...  Monday is not so bad; it's $^&*^^ like this that gives Monday a bad name.
Audit could not correct errors in database...
I don't recall having my file crashed, but I tried to access this file and the program said I need to do a recover, long story short I got this message at the end. Now I can not access this file? All my works from previous week are gone?
Is there anyway around this?
Appreciated if anyone can help,
Tee
Tags (1)
6 REPLIES 6
talles.projetos
in reply to: tpham2001
Access options !!! Is there the 2 files savo last time. ok??
ok for the solution?
tpham2001
in reply to: talles.projetos
Talles,
Thank-you for the response. I tried the steps as you suggested and it seems to work.
It's a little too late for me now since I went back and redo what I did last week; mind you it was not a big project but still a lot of wasted time.
Thank-you,
Tee
Another workaround is to simply copy the file into a new dwg from your desktop and specify 0,0 as insertion point and 1 for the scale factors. Then you can rename the dwg file after and audit/purge the drawing.
Alternatively you can start a new drawing from a "template" and use your current corrupt drawing as the dwg template. Seems to clear errors for me with no loss of data. Works most of the time.
I've the same issue not able to recover or open the file.
also I checked the Temporary Dwg. File Location it looks with two names.
please explain me how to solve, this is company's PC.
Temp. Location with Two Names.JPGLevel-2 Recovery-1.JPGDwg File Location.JPG
”Boost
”Tips
