Hi All,
I was looking forward to a good start for Monday... Monday is not so bad; it's $^&*^^ like this that gives Monday a bad name.
Audit could not correct errors in database...
I don't recall having my file crashed, but I tried to access this file and the program said I need to do a recover, long story short I got this message at the end. Now I can not access this file? All my works from previous week are gone?
Is there anyway around this?
Appreciated if anyone can help,
Tee
Solved by talles.projetos. Go to Solution.
Talles,
Thank-you for the response. I tried the steps as you suggested and it seems to work.
It's a little too late for me now since I went back and redo what I did last week; mind you it was not a big project but still a lot of wasted time.
Thank-you,
Tee
Another workaround is to simply copy the file into a new dwg from your desktop and specify 0,0 as insertion point and 1 for the scale factors. Then you can rename the dwg file after and audit/purge the drawing.
Alternatively you can start a new drawing from a "template" and use your current corrupt drawing as the dwg template. Seems to clear errors for me with no loss of data. Works most of the time.
I've the same issue not able to recover or open the file.
also I checked the Temporary Dwg. File Location it looks with two names.
please explain me how to solve, this is company's PC.
