AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Assigning shorcut key D
1 REPLY 1
SvenVer
363 Views, 1 Reply
My problem:
I can change the purpose of the shortcutkey D (original dimrotated). But the problem is that what i do if you put "D" in your command list, is saids "distance= 0.00000 (read only)" even if you didn't change it.
This is only in structual detailing, if you go to the normal autocad you can use the comment.
Any solutions?
1 REPLY 1
Open Acad that work correctly and under the manage tool of the ribbon open alias file acad.pgp. then select all and copy (ctrl+c), close without saving. Now open ASD and open acad.pgp as previously discribed, select all and paste (ctrl+v), save the text file, colse notepad and close ASD.
restart ASD and averything will be ok!!!
Greetings.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
”Boost
”Tips
