AutoCAD Structural Detailing General DIscussion
Active Contributor
Delvin.Ramassami
Message 1 of 6 (448 Views)
Assembly query
448 Views, 5 Replies
04-24-2013 11:16 PM
Having a problem with assembly drawing
- An assembly AB 8 whereby automatic drawing is done (Expected to have the AB8 And the B8 details ) but only having AB8 as drawing
- the detail of the beam B8  is not attached to the assembly  drawing of AB8
The why of this ?????????
refer to annexed picture
Product Support
Jakub.Brozonowicz
Message 2 of 6 (423 Views)
Re: Assembly query
04-25-2013 06:48 AM in reply to: Delvin.Ramassami
Is "Assembly and parts" mode chosen for views arrangement?
Jakub Brożonowicz
Active Contributor
Delvin.Ramassami
Message 3 of 6 (416 Views)
Re: Assembly query
04-25-2013 07:01 AM in reply to: Jakub.Brozonowicz
Yes Assembly and part have been selected .
Note that the assembly is a loose part one - does this change things ?
Product Support
Jakub.Brozonowicz
Message 4 of 6 (409 Views)
Re: Assembly query
04-25-2013 07:22 AM in reply to: Delvin.Ramassami
Yes.
Look here how it works if you have another part (plate).
It is possible to add and remove the additional fiction part and stay with requested drawing.
Jakub Brożonowicz
Active Contributor
Delvin.Ramassami
Message 5 of 6 (406 Views)
Re: Assembly query
04-25-2013 08:21 AM in reply to: Jakub.Brozonowicz
Ok good but is this the right way is there any other way ?
For my case  :-  a beam is site welded at both end an considered as an assembly loose part
it give me only the assembly part but not the detailed profile ..
But
when having clip angle it works as intended giving the assembly,  the detail profile and plates
why not for loose assembly ?
Active Contributor
Delvin.Ramassami
Message 6 of 6 (386 Views)
Re: Assembly query
04-25-2013 09:49 PM in reply to: Delvin.Ramassami
Another Easy and relatively quick way is to add the details profile that is Add to current printout .
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
