AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Advance Concrete
17 REPLIES 17
Message 1 of 18
Redli1
8541 Views, 17 Replies
Advance Concrete
I installed the trial version of Advance Concrete 2015 and I am very disappointed. The program is way behind to ASD for reinforcement drawings.
It does not exist a discussion for Advance Concrete. Has anybody tried this software?
17 REPLIES 17
Message 2 of 18
and-adsk001
in reply to: Redli1
Message 3 of 18
CristinaJianu
in reply to: Redli1
Hi Redli1,
I have worked with Advance Concrete.
I could help you with any questions you may have.
Please let me know
Message 4 of 18
zcsillag
in reply to: CristinaJianu
Si **** ti se pare fata de Allplan ?
Regards
Csillag Zoltán
Message 5 of 18
CristinaJianu
in reply to: zcsillag
I don't know that much about Allplan. Haven't worked with it.
I do know about Advance Concrete 🙂
Cristina
Message 6 of 18
The Advence Concrete has bug? Works well?
The detailing and design generated autimaticos are good?
The module has Advence Concrete for precast or prefabricated?
Thank you
Message 7 of 18
zcsillag
in reply to: talles.projetos
Test trial 😛
Regards
Csillag Zoltán
Message 8 of 18
I did both precast and cast in place details with Advance Concrete.
You can try it and if you stumble upon something you don't understand you can ask me Smiley Happy
Message 9 of 18
szokolsz
Hello !
I`ve got a proble with the reinforcement drawing.
When I create one from the 3D model and leave the 3D power turned on, everything works fine. The 3D power forks fine.
But, when I close the program and (lets say on the next day) reopen the drawing and trying to continue the work, the 3D power doesnt work anymore.
What coul be the problem?
(Its not a trial version)
Message 10 of 18
please is it possible to do rebar surface reinforcement for slab detailing in advance concrete? This feature is available in ASD but i can not find it in advance concrete. I don't want to use mesh.
Proudly Nigerian
Message 11 of 18
Hi. Is there any way to make reinforcement section non perpedicular to WCS?
Thanks.
Message 12 of 18
ks.rotanak
Could you please tell me how to create the list?
I have tried modify existing list by added column and variable, but the total weight changed, sometime disappeared (ex. <sum(col[...])>).
Message 13 of 18
CristinaJianu
in reply to: ks.rotanak
Could you please send me the file and also tell me which version are you using?  🙂
Cristina
Message 14 of 18
ks.rotanak
Hi
Please check attachment for list i currently use.
I tried to add column (Number of Element) with attribute
but it doesn't work.
You will see at the bottom, i don't know where is number 4
come from. If i added more attribute, do i need to change this number or
not?
Thanks for help 🙂
Sambo Rotanak
Message 15 of 18
CristinaJianu
I can't see the attachment. Could you please send it to my email address: cristina.jianu@autodesk.com? 🙂
Cristina
Message 16 of 18
CristinaJianu
Cristina
Message 17 of 18
jrmcmarin
buen dia, envio informacion espero solucionar tu problema
Message 18 of 18
ks.rotanak
in reply to: jrmcmarin
It is a big help.
”Boost
”Tips
