I would like use a Reinforcing Steel with a diameter = 18mm.
But in the list, I can only choose 16mm or 20mm...
How can I add a new diameter?
Thank you for your answer, and I apologize myself for my bad English (I'm french).
Try to explore the "Edit bar database" command (Command Line: RBCR_TOOL_DBEDIT, Ribbon: ASD - Reinforcement > Modify > Edit bar/wire fabric database).
The database's files you must seek for are bar_**.XML, not fabric_**.XML (where ** is the name you have selected in preferences).
Try it and then write here again if you can't resolve your issue.
Good luck!
