AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD2013 I can not change the name of Detail Symbol in model space
5 REPLIES 5
and-adsk001
539 Views, 5 Replies
View name changes, but Detail Symbol name does not 😞
5 REPLIES 5
pendean
in reply to: and-adsk001
Method?
Then, why?
and-adsk001
I think there is only one method to rename Cut symbol or Detail symbol  - Object Inspector. I highlite Cut (Detail) name, Double click, enter new name, Enter button. Cut symbol name changes, Detail name - does not.
pendean
RENAME command? otherwise it would appear Autodesk doesn't want you to rename their provided content.
in reply to: pendean
If I'm understanding correectly, andmail wants to wants to rename the cut, not any Autodesk content. Therefore on the dimension drawing you would see cut B-B rather than A-A, for example.
If that's the case, the cut should be able to be renamed. I've done it before. Most of the time I just make manual cut symbols in paper space because I don't like ASD's cut symbols.
and-adsk001
It's very simple to create single profile, then create one detail view on it.
Then try to rename. Detail VIEW NAME will be changed, but its SYMBOL doesnot 😞
I think this is not right, is not it?
With CUTS there is no problems. VIEW NAME and its SYMBOL will be rename.
Now I see only two solutions:
1) Manual creation the detail symbols
2) Re-creation detail view with the new name )
”Boost
”Tips
